looking for an 07 LBZ turbo vane position sensor
serpa4
Feb 5, 2007
402
Anyone have an extra one laying around to let me test to see if mine is bad? Mine has a black wire coming out of it. I tried one with a white wire, and the connector is different and will not mate.
the4wheeler
--->(Something Funny)<---
May 4, 2008
254
Ventura County SoCal
the connector with the wight wire will work you just have to trim the tab that under 2 of the 3 pins with a razor blade take your time but it will plug right in and work just the same.
the4wheeler
May 4, 2008
254
the plug basically looks identical and the pins are in the same location just on one there a little tang that on the top one side or on the bottom the other side on the other connector ( on the in sided of the sensor connector)
wow that a lot of sides to be talking about
