Hey all,
new guy here. I bought my LMM in march with 51k on the clock. Just clicked 60k
My goal with this truck is longevity/reliability in conjunction with moderate power gains. I do not race professionally, sled pull or compete with it in any way. I tow a few times a month around 10k lbs, an odd load will hit 14k lbs. The truck is my DD and sees city, rural and highway. It will see moderate off-pavement usage I.E. beach, hunting trails, mountain access roads etc. Since taking ownership I have treated each tank and will continue with that practice.
The following list has already been completed. The truck came to me with a zone level kit (keys,ext mounts) and an AEM intake.
1. EFIlive via PPEI, DSP5
2. Flopro 4" DP back
3. Front end: Rare Parts Idler/Support/Pitman/Tie-rods
Moog UCA's, problem solver with added camber
Moog LCA bushings, Mevotech TTX lower ball joint
Dmaxstore XD hubs x 2
Moog end links/alignment parts
ACdelco spindle bolts
Rancho 7xxx Stabilizer
4. Bilstein 5100's all around
5. Moog 1480 U-joints - serviceable
6. AEM Brute Force CAI (new model via warranty replacement)
7. Wheels/Tires 265/60r20 - 20x9 w/ 10 offset
8. Amsoil F-diff/R-diff/Xfercase/Oil/Chassis - Transynd flush
9. Hydroboost flush
10. Gates HD Serp with pulleys/tensioner
11. Edge CTS2
12. Alpine Component speakers with amp/sub inbound
13. Updated rear cab mounts
14. Full intake/EGR cleaning
Next on the list is a lift pump. I plan to use a kennedy single pump. I have not decided on a filter head yet. Past that, i'm really at a loss as far as what to do. Below is what I have thought of, in the order I would assume makes good sense. Please feel free to recommend things, point out my failings in planning or whatever.
Rust mitigation - POR15 or maybe Zeibart if lazy
Injector/Top end cleaning with the GM juice
EGR delete - Deciding on method and vendor. Y Bridge?
Trans - Limitless Diesel since I am in MA.
Ported fuel fittings, frpv shim
manifolds/up-pipes/downpipe - Pro fab
Intercooler/pipes/boots - AFE or WCfab if avail for LMM
Thanks all,
jack
9. Hydroboost flush
11. Edge CTS2
Thanks all,
jack
