Help: looking for a 7/16" stud
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
7/16" x 2 inch or 2.5" preferably SS but not fussy
Ive seached ARP site blower studs and some head studs nothing seems to match what I am looking for
6 point or 12 point will work,but i dont need rocker arm studs
they have to be studs! Just like head studs just shorter
thanks for any help
mytmousemalibu
Cut your ride, sissy!
Apr 12, 2008
2,230
Kansas
BTW Simon, just in case you find some, BLOWER studs are generally made from aluminum. there made this way as a last resort, in a blower explosion the studs will rip apart to save from exploding the blower case or tearing up the intake in the event the burst panel isnt enough! Saw you said stainless, so just incase strenth is a concern!:hug:
On Edit, ya i wouldnt use them for that, plus heat will makem weaker
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Ive read that before...since ive got no personal experiance with blowers
So ill keep that in mind thanks:)
9,903
149
Fine or coarse thread Simon?
On our buddy Chris' site he posted, check under Head Studs. There are 7/16" x 2 1/2" coarse x fine thread studs that would work I think.
mplteddy
574
49
Central Alberta...
www.mplmotorsports.ca
The more "explosion proof" Simon builds his stuff the better....:rofl:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
If you are talking about pedestal bolts:
I actually helicoiled the holes, then put in 10mm set screws with flange nuts:
7/16= .437 OD
10mm= .394 OD, to give a little more play.
Metric so I don't have to find an inch wrench.
Flange nut so I can use a smaller wrench, more room.
Set screw so I can put an allen in it and screw it down if I have trouble removing charger.
