My Fiancee's 03 LB7 is having to crank 5-7 seconds before starting.
I was getting a P0380 code but I think that has been there a while. I replaced both of the relays in the glow plug module which are way cheaper then buying a new module(Napa Echlin part#AR282) and all 8 glow plugs. No more code but still very long crank before start.
Balance rates are good
Logged rail pressure when cranking and it starts at 200 and slowly creeps up then when it hits 1400psi it starts, like it should right?
Checked FRP with DVT and will only hold 14k when 23500 is commanded.
No fuel in oil. Primer is not hard after you start it. I deleted mine and never checked the primer unless I replaced the filter so I am not sure if the primer stays hard all of the time unless you lose prime?
Im running to the parts store right now to get a non vented cap and pressurize the system and wanted to see if anybody else had any thoughts.
