logging tcc slip
02bigstrokin
Sep 9, 2008
882
is there something i have to download or update in order to be able to select the pids for the transmission? they all have x's through them. i have the latest 7.5.5. do i need the 8.1 or wtf?
Brian1
Jan 1, 2008
103
Connect to the controller and then Validate PIDs under the Info tab. See if that helps.
Brian
JShe8918
Feb 17, 2009
190
I asked this question once before and they told me to Validate the TCM PIDS after connecting and then everything should work.
02bigstrokin
Sep 9, 2008
882
i just tryed validating the pids, nothing:mad: i guess ill just have to find someone with a tech 2
Dec 2, 2006
1,696
TN
Do you have a V2? or V1?
If a V2, just use BBL(Black Box Logging) and it will work for you. The Pre-Made LBZ pid set has the TCC Slip already selected for you.
