logging lbz pulse width
onebaddmaxxx
1,212
Cecil County Md
Ok I am trying to do some logs on a truck, but having issues logging the the pulse width. Physically, It logs it perfectly fine. But when i play the log back and have the tune open, the grey cell is not in the correct spot. I have looked at all the other tables and it is displaying them correctly. When I playback the log, the Pulse width table just stays at 190mpa (all the way to the right) and just goes up as the mm3 changes. Im using the factory preset lbz dashboard. Any help is appreciated. Hopefully its just something as simple as selecting an extra PID. Thanks
slipclutchms
427
Are you using LBZ metric PIDs? If our logging PSI instead of MPa I dont think it will correspond in your runway highlighting....
onebaddmaxxx
1,212
Cecil County Md
Ok so I figured out if I have a dsp tune open, if im in the main calibration file, and play the log back...it will follow right along in the tune. If i open pulse width tables in dsp1-4 sections, it doesnt work properly. Only works correctly in the main file. Anyone experience this?
gmc502
468
13
Any more info learned about this?I seem to be having the same issue.my logs are all being displayed in the 190mpa column.
