i know what I'm looking for, but i dont know how/where to find it. or if it is even here.
I don't THINK it works like that... Meaning that we tell the ECM what timing to put where in the software tables of efilive before we upload it to the ECM to command the parameters we ask of it...
Outside changes IE - water meth I don't think it will read because there's not a sensor for the timing like a gasser... the timing from how I understand it on the diesel is in a simplified 2 step process... the timing actually starts it by telling it when to fire the injector, and then commands how much mm3 to spray by using the pulse width.
So the third step you added with the water/meth it has no idea about... it's mechanically doing it, but, electronically it has no idea...
So if we changed something in the cylinder the computer can't 'see' it to show it in a log...
With that said - keep in mind I'm learning too; so If i'm dead wrong, go easy on me :rofl:
