Lmm turbo
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
Plenty of trucks running better turbos. If you stick with a VVT , you're only holding yourself back.
whitelmmmax
Smaller than stock
Jul 26, 2011
693
lake charles, la
That's what I'm beginning to see. But everybody I talk to around here says to stay with a vvt like a 4094. But I like to be a lil different, but I also still want quick spool up
TeaBagger2006
May 11, 2008
3,123
15
Bis ND
well a 4094 is cool because its just a drop in replacement for the stocker...... but there are plenty 66mm chargers that spool just as quick if not quicker than a stock turbo.the billet turbos are sweet. trent will surely steer you in the right direction.
Sep 10, 2008
1,072
Morehead City, North Carolina
My buddy Tyler (08lmm) just had Dustin @ Diesel Addiction install a s366 billet double batmowheel turbo with a race cover, 100 over injectors and stage 3 pump. By far the fastest spooling truck I've ever ridden in. It would rip the tires loose at 60 mph 50 lbs of boost. Sounds pretty cool too!
whitelmmmax
Smaller than stock
Jul 26, 2011
693
lake charles, la
Like the sound of that! So there is a billet and double batmo wheel version? So there are batmo wheels for compressor and exhaust?
Forever
This 1 time, at band camp
Jan 4, 2009
363
Utah
Can someone explain what some of the VVT's downfall is?
I'm not trying to hi-jack your thread. I want to know the same question.
TeaBagger2006
May 11, 2008
3,123
15
Bis ND
drive pressusre is killer! small exhaust housing makes egt's soar through the roof and creates to much drive pressure which can damage your turbo.
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
or put a hole in your piston as several using 4094's have already experienced.
id do a s374 or s475 billet and be done with it.
some batmowheels have been dyno proven to loose HP vs their billet counterparts so at this point i would recommend doing a billet 366 w/ race cover if your worried about both spool and power.
fwiw the batmo wheel is a huge sales gimmic. IMO
Colt
Jul 23, 2010
523
Did McRat run twins on Casper on that Salt Flats run? Seems like they said it was a single to make the rules to qualify on truck's engine mod. allowances.
