I searched around and I couldn't find the answer to this.
Can you bolt a LMM transfer case up in place of a LB7 transfer case?
The reason I ask is because the LMM transfer case "supposedly" fixed the pump rub problem, and I started to wonder if I happened to come across a new T-Case, could I use it?
I realize this is probably not the cost effective way to fix the pump rub problem, but I wanted to know, for the record, do they interchange?
