What would it take to make an lmm work in a lly ( IE 2008 lmm in a 2005 llly )
What needs to be changed to make it work in a 2005
why would you want to do tht? just curious. I think you would pretty much have to use lly heads injectors and what not for it to all hook up
Glow plugs are the same, injectors are slightly bigger (.020").
If you remove the front cover, grind off one tooth off the reluctor, use a bigger o-ring on the LLY injector bodies, you can bolt the LMM in as far as I can tell. You would need to use the LLY engine harness, computer, injector controller, and might have to "stretch" the boost sensor wiring.
The sensor has been relocated, but should stretch.
If you want full output, program in 180mPa instead of 160mPa (LLY)
What I was thinking was chances of leaking past O'Ring ???????
