LMM Throttle Body(looks like one anyways)
Sagebrush Assassin
Jan 28, 2010
12
Odessa, TX
I found this in McRat's glossary of terms..
DPF = Diesel Particulate Filter system, which is exhaust, sensors, and throttle butterfly. On LMM only
If that is so then turning off the codes for DPF should turn that off too or seems so..maybe not.I do not have EFI yet.Thanks for the help..
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
DPF is the exhaust filter, it is part of this system, however, just disabling the DPF and regens will not shut off the AIV, you must set the AIV out of range and set the codes to not report with EFI Live.
