LMM tap shifter not working
lutzjk913
1,689
182
groveport, ohio
Found this issue when I was pulling a trailer and went to manually down shift.
Tow haul still works
When I pull it down into manual mode it will stay in whatever gear it's in and won't shift up or down
Any insight on this guys?
Thanks joe
KyleC4
470
Bay Area
Could just be the shifter assembly. Best way of knowing of course is with a tech 2 and seeing if the TCM is receiving the tap up/down shift signal from the lever. sorry I don't have better insight then that
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
My fathers did this the other day on his lly. Once you tap it down it sticks in that gear. I think he cycled the ignition on the side of the road and it was fine after that. When i talk to him ill ask what he did.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Try calling the vendor you bought it from. Why would you ask this here?
I think he's asking about this on an LMM Mike. So it would be factory. Not an add on like the LB7 or LLY trucks.
I've never seen this issue before so I don't know. But maybe a nsbu switch issue. But I agree you need a tech 2 to see what's going on.
lutzjk913
1,689
182
groveport, ohio
No matter what this stays the same.
This is on my LMM and is factory
Yeah this is on my LMM. Ok. Thanks.
Might be making a trip to the dealer
kiwilml
454
I had an 06 lbz I just sold and that button don't work half the time it didn't seem like.. So I could believe it could be just the button..
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Tap Shift
I would bet a broken wire on the shifter. Snap on or Tech 2 should tell you if its working. I have a shifter in stock if you need it.
03blkdmax
Turbos are cool
Jan 23, 2016
22
PA
Check the ign 0 fuse in the little fuse compartment right by driver door.. that was the problem on an lbz
