LMM or LML engine hrs.?
trashygasman
Slowly but Surely
Dec 18, 2008
637
49
Washington, OK
Can they be accessed through the DIC? They are wanting to start doing our oil changes off of hrs instead of miles since our trucks idle so much. Since they are base models, they don't have a DIC, only the button on the instrument cluster. I was wondering if anyone has added the DIC from LMC Truck and will it show hrs? A guy I work with added one to his gasser and it does. They took one of our trucks to a dealership and hooked it to a scan tool and said it wouldn't show engine hrs.:confused: I was planning on getting a DIC anyway, but if Halliburton will buy, it will be even better.:woott:
08txlmm
75
Lubbock
My LT trim LMM has engine hours in the DIC. I don't know about the DIC you mentioned from LMC Truck though.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
On my truck you just press the odometer button on the cluster a couple times and scroll through trip odometer, odometer, and engine hours. I dont have steering wheel controlls.
1chevy02
Jun 23, 2009
504
On my gasser if you pushed and held the odometer button for a while with the key off it would show hours I believe.
1chevy02
Jun 23, 2009
504
I have not tried it on a 11 or 12 model but, it works on the previous models that do not have a dic. You have to hold it for a while.
gr8shot
Practically stock
Apr 28, 2009
262
3
Grand Island, NE
On the lmm you can just buy the dic buttons, remove the trim piece and plug em in and voila you have all the controls you normally do with a dic equipped truck. Id think the lml would be the same since Its the same interior.
Sent from my old skool Droid
gr8shot
Practically stock
Apr 28, 2009
262
3
Grand Island, NE
I'm sure it will. If it does on trucks with dic controls then it should once you add the buttons. My lmm did so I duno why it wouldn't
trashygasman
Slowly but Surely
Dec 18, 2008
637
49
Washington, OK
Yeah it works. Hooked the one up off my buddies gasser. They are buying them for all the chevys at work now.:banana: Thanks for the help!:thumb:
