Seems as if the torque converter is staying locked, which im assuming is the solenoid in the tranny which is what i will try
THE BIG ISSUE
While in gear, the truck tries to take off which is more than likely the tc, but holding the brakes and holding wot, the truck will not gain rpm, like for some reason it is not fueling, i looked at the tune with efi and everything seems fine, even flashed with another tune.
driving normal, and taking off seem ok, when it gets to 1500 it will run perfect like it should and fuels just fine. pedal sensor 1,2,3 all read 100% at wot.
2008 crew dually duramax auto all stock
with the tc locked would the computer maybe not let it fuel since its not moving ?
THE BIG ISSUE
