If you basically convert the LMM into an LBZ then yes it can work. The biggest thing is the ECM tuning though as the LMM ECM uses a differrent communications protocol than teh LBZ does from what I understand. And due to the 6 hole VS 7 hole injectors the tuning will need a few tweaks to work right as well I believe, so you will need EFILIVE. Or you may be able to swap injectors I think and have an actual LBZ out of it.
