Lmm Injector nozles
slowlmm
Mar 2, 2008
2,582
46
so cal
I was wondering what a spare new or used set would go for. i want to send mine out and have them done. but didnt want the down time of the truck. would this make since to have a spare set. or is it a waste of money. Also who would be best to do the honed nozeles Thanks :)
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
let me know what you come up with. That place you told me about has a "group buy" discount, I'm prolly goona send mine here when we pull the motor.
slowlmm
Mar 2, 2008
2,582
46
so cal
Just honed or some extra holes also, how much % we are talking ? :D
V :angel:
Well i duno what would you sugjest. i dont no verry much on the subject. I still want it to be verrry streetable but match well with a modded vvt and twinz. and not sacrafice fuel mpg. so i duno 30-40% i guess. wht benefit would the added holes give ? Thanks:)
mde
fuel injection is my life
Mar 17, 2007
396
Bucky State
The stock injector has an 158 degree spray angle, so when you go with a :quote: little bit more aggressive :quote: tune, which means you have more advanced timing, which also means you don't hit the bowl right. With this adjustment we are sure that a part of fuel hits it right, also the chance to wash the walls down. But we can adjust the second spray angle to your driving habbit :D
What I usually do is: take all nozzles, extrude hone them to the same flow +/- 1%, then EDM it with the OEM machine, then extrude hone them again to +/- 2% flow (OEM specs are +/-5%)
I hope it helps ...
V
slowlmm
Mar 2, 2008
2,582
46
so cal
yes tht helps:) thanks for the pm as well. i will be contacting you soon about those Thanks Tommy
