LMM elevated idle will not turn on
Chadball
Oct 26, 2014
I have a 2009 LMM and my elevated idle will not turn ON. I have used both the DIC to try and turn it on and also pressed the gas in and tap the brake 3 times. It will pop up saying elevated idle but WILL NOT switch to the ON setting. Continually says OFF after trying each process. My check engine light is ON. Does this happen to screw with the elevated idle and stop it from going on?
Chadball
Oct 26, 2014
going to elevated idle on the dic and pressing check mark and it will say. Elevated idle off. Then if you press it again it says OFF selected. Going to scan it tomorrow when I get my EFI scanner.
f1100turbo
Sep 8, 2014
40
It's through the fuel and brake pedal as the op stated.
Without looking at the manual myself I can't remember.
Op if you don't have a manual I think there's a you tube video on it.
Or at least there used to be.
Turbs
Chadball
Oct 26, 2014
Ya it shows up on the DIC, but still says off no matter what I try. Also, did the same thing the youtube video asks and it repeatedly says OFF. Cleared all the DTC codes and it still does this. Might run it into the dealership I guess.
Chadball
Oct 26, 2014
Scanned the truck and it came up with DTC code C3300? Appears that I can only find DTC codes that start with a P??
