Hi everyone, I have a 2008 LMM. The truck has always turned over very slowly and takes a second to start. I thought it was just a dead battery but I'm afraid its something more. If I disconnect the passenger side battery so only the drivers side is connected, the truck is dead, only the check engine light shows up very dim. If I unhook the drivers side battery so its only running off the passenger side, everything comes on like normal. Its obvious to me its just cranking off the passenger side. The drivers side battery tested at 12 volts. I also put a new battery in the drivers side and still the same slow crank. My next guess is maybe the drivers side battery cables are bad? Maybe it could be a ground? I don't know why the drivers side isn't giving any power when the battery is good.
