LMM Block and Crank needed ASAP
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Still looking for a block and crank, short block, anything really.
Everyone that says they have one flakes out on me...........:(
This trucks never gonna get done.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Wish we could help:( The only spares we have are fully built LLY and LBZ and they wouldn't be cheap.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Let me clarify what Kat is referring to.
It's an LBZ engine that is balanced and build by BMS Machine who does all our engines. It has de-lipped LLY pistons, Crower rods, SoCal Diesel cam, pushrods, springs, ARP headstuds, and runs thin gaskets. It is intended for a 4500 rpm application.
It is currently zero hour and saran-wrapped. It was intended as a backup engine for the 2007 race season, but wasn't required. It is outright, no core, and a Long block. You will need injectors, fuel lines, turbo, wiring harness, CP3 and accessories. It comes with harmonic balancer and flex plate. It will probably go into Wendy or Blue if either runs into problems, as Casper has an LLY backup engine ready to go.
Alligator
Nov 9, 2006
1,919
N. Idaho
How much?
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Is Casper currently running de-lipped pistons?
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
Nice!:D Wasn't sure.
The only difference between the 2 engines is the one that is in there now is a LLY block and a LBZ cam. Opps and the ported heads are currently on Casper.
Like I said earlier we are not even trying to sell the spares.
IdahoRob
Jun 5, 2007
1,151
I was up in Montana last weekend and there is a brand new LMM engine sitting on the shop floor. Not sure what they want for it, but it is complete from turbo on down.
G & J diesel in Billings, MT. Talk to Brad. Not sure if they even want to sell it, but worth a phone call.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
thanks for the info, Ill give em a call in the AM
ripmf666
15,123
14
47
Wentzville Mo
As far as I can tell no the block is the same, just look at the gm specs I posted about the LBZ and LMM stroke bore and all is the same.
