Lml stuck in high idle?
Nov 27, 2022
53
Hi all, I just swapped an lml engine into this truck and it seems as if it’s stuck in high idle when it starts? Im guessing it’s around 1200 rpm as the rpm gauge doesn’t work and if you hit the break it will idle down to what sounds like just above regular idle until you let off the break. I’m getting codes for the maf sensor and the accelerator petal position sensor aswell. Any help would be greatly appreciated!!
P2138-00
P2128-00
P0098-00
Also if I can figure out how to upload a video I will do so of it starting up
Nov 27, 2022
53
P2138-00
P2128-00
P0098-00
Below I have attached one video with the truck running with the other engine (broken crank) and one video of the truck running now.
Source: https://youtube.com/shorts/u44k8SP4umA?si=AyW5Mw6clZl7d4VJ
Source: https://youtube.com/shorts/2Bo8WnWJey0?si=JK3aE4DyOvigV0An
Also I have learned the truck is idling at 1000rpms and 800 ish when the brake is depressed. My cts3 can read the rpms
darkness
1,294
363
vegas
I’m not much help here but it’s either wiring or the maf. It’s going into elevated idle cause it thinks it’s cold. My lly will do the same thing when I have the maf unplugged.
