Two Fuel Rail Pressure Regulators (FRPR) are used. FRPR1 is still located on the injection pump as on previous Duramax engines. FRPR2 is located on the front of the left fuel rail. This solenoid is normally open. The ECM supplies pulse width modulation to change the duty cycle of FRPR2 to control the amount of fuel returned to the fuel tank.
The new Duramax engines are equipped with Bosch piezoelectric fuel injectors. These injectors operate a high voltage, indicated by the orange color of the injector harness.
IMPORTANT: Do not make contact with the fuel injector harness, ECM or fuel injectors while the ignition is in the On or Run position. Use certified insulated gloves EL-48286. These Class 0 gloves are rated at 1000 v. Check for functionality and check the expiration date of the gloves.
The ECM supplies high voltage and provides a ground. Voltage is supplied up to 160v at 20 amps, and can peak up to 240 v. This causes the injector to open. The capacitor discharges through an injector for initial opening and holds open with 12 v.
Injectors are grouped into four pairs: 1-4, 6-7, 2-5, and 3-8. If a condition is detected in a group, that group is disabled and a DTC is set.
On the fuel system return side, the return lines are now equipped with snap-in connections. The return side is under pressure.
A pressure retention valve maintains 0.4 to 1.1 mPa of pressure within the return lines to provide proper fuel injector operation.
TIP: Improper injector return line pressure may cause a no-start or performance concern.
If the engine runs out of fuel, or if the fuel system is serviced, the system must be primed. After priming, a feed line from the low pressure side of the pump backfills the injector return lines. The feed line will also backfill if pressure falls below 0.3 mPa in the injector return lines.
http://www.sandyblogs.com/techlink/2010/06/new-duramax-diesel-engines.html
