Anyone know if it's possible to swap out the stock LLY fan clutch for one meant for an LML? I believe the LLY ECM has a temp trigger circuit, if i've read it right; just means adding the appropriate pin(s) to the ECM connector for triggering the clutch in & out?
Reason i ask is because i tow a big-ass horse trailer with my '05, i don't push it hard but we have some 13% grades around here & in the summer i usually end up stopping part way up & waiting for things to cool off. Running a CTS2, keep in the mild tow tune setting, put in a cold air intake, changed the turbo inlet, put in a Mishimoto rad last summer (which did virtually nothing) ... the stock fan hub doesn't kick in until 220 or higher, by then it's just too hot to cool down. I'm thinking since the LML fan clutch is electronically controlled, i could put a manual over-ride switch in & get the fan turning earlier, or just program it come on sooner.
