LML CP4 Problems
Janimal444
354
Salem, NH
I did some searching and found some information on this but did not find a thread dedicated to this subject. I have heard claims of failed CP4s wreaking havoc on the entire fuel system. Basically I am wondering the following:
-How exaggerated are these claims? does anyone have any firsthand experience with this happening or know of anyone who has experienced this issue.
-What causes this issue. I have heard that the current ultra low sulfur diesel has a lubricity which is lower than what is recommended by Bosch to run through their CP4 pump, is this true?
-What can be done to rectify this problem? (Lift pump, aux. filter, additive etc.)
Since I'm in the market for an LML I'm just starting to do some research on these trucks, this is the only thing I saw which really stood out at me.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
only thing that can be fixed with that issue is swapping in a CP3 kit. IIRC I think Fleece has converted one, not sure. As far as first hand experience, I have none, but on duramax forum, there is 5-7 guys that have posted about their failed engines.
Dirtymaxx03
3,109
I believe it has something to do with what the plungers inside the pump are made of.
The ceramic plungers inside the injection pump of one of our 450ISX Cummins exploded and took out the whole motor.
ryan415
Oct 24, 2012
371
860
We've had a few trucks with cp4 failures and have ended up replacing the entire fuel system. Trucks are 100% stock. Iirc it's due to the ceramic plungers as Dirtymaxx already said. I know fleece and maybe also wehrli make a cp3 conversion kit.
02greysixer
1,829
North Central FL
We've seen it go both ways. One bone stock Duramax got by with just a new pump. The other two I remember were 6.7 Powerstrokes and they had to have complete systems done.
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
Over 50k on ours still going strong no issues. One trip towing heavy with it you will be in love. All trucks have there issues, and I feel the cp4 claims are exaggerated, you only hear about people posting the bad stuff, no one posts about about thousands of trouble free miles
gmac32
288
3
bellville ohio
I replaced a friend of mines entire fuel system because of the cp4. It had a little over 100k on it and out of warranty. I tore the pump apart and saw the bores were all scarred up and one plunger wouldn't even move. The rollers on the bottom of t!he plungers had complete flat spots in them to where they wouldn't even ride on the cp4 cam right. Junk Pumps period!
Independent03
Mar 23, 2012
Put me on the list. I've got a 2015 with 17k and the pump went out 1000 miles from home. All stock. Needs a whole new fuel system. Dealer said it could be two weeks. Not happy.
islandgirl62
On the road again......
May 22, 2011
Live in a 5th Wheel Full-time!
My 2012 took a dump on me, going 80 mph down the interstate in Wyoming, with 77,000 miles on it. (H&S Street Tune, FASS lift pump, cold air induction and 4" exhaust) A big shudder, dash flashed "Change Fuel Filter" then "Engine Power Reduced". Coasted to the exit ramp (fortunately it was MY exit!) that's when I realized the truck had completely shut down because I didn't have power steering anymore. Threw 7 codes, the first of which was Low fuel rail pressure. Most of the rest had to do with the truck having shut down and still moving faster than the CPU thought it should be moving. FASS filters had metal shavings in them. Factory filter had metal shavings in it. Still wouldn't start. Put it on a hook and took it to a diesel shop. Bottom line - they told me there is a service bulletin from GM on it. And the whole fuel system has to be replaced. (I have a copy of part of the bulletin where it mentions having to replace the whole fuel system if metal shavings are found.) So I'll have new everything, rails, injectors, pump, fuel lines, high pressure lines, etc. I asked the mechanic specifically and he said I have a CP3, not a CP4. That was a bit confusing because I'd been told by others that the 2012's all have CP4s. It's gonna cost me plenty to have it fixed. I didn't find out about the service bulletin until it was well into the tear-it-apart stages trying to find what all was damaged when the pump went out so don't know if I'll have a chance at getting anything back from GM for the repairs. Up until this happened, the truck was running like a champ. No rough running, missing, sluggishness or anything. Just WHAM and done! Can't wait to get it back. Should be done Thursday!
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,198
362
At Da Beach
That's terrible luck man I hate to hear that. Unless you swapped out the cp4 the mechanic is wrong. I would not go back with a cp4, there are cp3 conversion kits available for relatively cheap.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
106,000 miles on mine...has anyone done any studies regarding additive, if it helps at all?
I dont have time/money to dick with a CP3 conversion right now...maybe this coming spring. I could care less about performance, I just want it to be reliable.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Was it covered under warranty?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
How many miles out of warranty was it?
Does the cab have to come off to replace it?
quadracer37
Mar 31, 2009
547
northern, IL
don't need to lift cab. we do conversions weekly here in just 3-5 hours (on Already EGR deleted trucks) with EGR your talking closer to 10-12 hrs
all failures we've seen have been related to poor fuel quality/contamination. once they fail is what really gets expensive. 9 times of out 10 requires all new injectors, rail sensor, DRV Valve, Return line assembly with check valve, drop tank to clean, and clean all other fuel lines.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Hmmmm...so I guess I should invest in an Airdog or Fass.
Like I said, I really do NOT care about performance on this truck. Its just for testing new products, and because all I want is to have a nice new(er), quiet, non-smelly, smooth, comfortable and RELIABLE daily driver...
