Lml c - 3 return springs and piston.
whitey
DIESEL NUT
Dec 2, 2014
207
Minnesota
I have a lml tore down. And noticed the c -3 return springs are stiffer than the previous years. Wondering what the reason for this was. And would the older models benefit from the stiffer springs? Also wondering about the c -3 piston, looks like it may hold up to ballooning better than the previous years. But not sure . Thanks!
13,714
776
LML C3/C4 piston and return springs are an upgrade over the old stuff. They must be used together.
whitey
DIESEL NUT
Dec 2, 2014
207
Minnesota
Thanks Josh. Can I use the c 3 return springs and pistons without the 4.? Or do both packs need to be done at the same time.
whitey
DIESEL NUT
Dec 2, 2014
207
Minnesota
What is the best c -3 available right now? I'm running Suncoast gpz waff design. I got a few set's from Andrew a couple years ago. They are not holding up.
whitey
DIESEL NUT
Dec 2, 2014
207
Minnesota
Got ahold of George at Suncoast, and he set me up with a set of g3 clutches to try. I will let you know how they perform.
