lly with lb7 short block
durawhore
Aug 19, 2014
124
Question so my buddy just picked up an 05 lly from trent nell's brother motor is in pieces I have a lb7 short block anything need to be swapped other then the top half heads injectors and all that good stuff
durawhore
Aug 19, 2014
124
I thought so to Mike just wanted to check thought I seen somewhere the balancing was different may be wrong tho.. so should be just fine to swap over heads and what not and it will be good to go?
