LLY: LLY turbo vane sensor
04D_MAX
force fed
Sep 10, 2012
384
SOUTH GA
Got a used turbo that supposedly came off a 06 H1 alpha hummer. From what I've looked up the motor is a lly in one of those but I got the turbo in and the vane sensor connector is not the same as the one I pulled out. So my question is, is this an lbz turbo or did they use a different sensor on the Hummer? And can I use the old sensor off my old turbo? The a/r is stamped .90 just like my original if this helps. Thanks in advance.
