Lly p1093
05Supersmoker
Aug 31, 2009
11
05 LLY is throwing a P1093, we put a race valve in it and have changed the fuel filter and it is still throwing it. Would a lift pump help or do I need to start looking at injector wiring?
Thanks, Cody
stacks04
792
Terryville,Ct
when is throwing the codes, what kind of tune you running? huge tune a lift pump would help that. if its a bad cp3 the lift pump wont help.
05Supersmoker
Aug 31, 2009
11
It just has a bully dog tune on tow and thats it. It happens as soon as you get on it at about 40-50 mph it just falls on its face.
stacks04
792
Terryville,Ct
not sure on specifics of bully dogs, but i doubt they are using enough fuel in tow to drain a rail like that. its either a leaking valve like kat said or a bad pump/regulator.
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
you might try a different setting on the bullydog and/or put it back to stock and see if the problem persists.
