Hey everyone.. new to this forum but I recently had some bad fuel I'm my truck and as a result have a no start issue. I pulled the tank.. drained it completely and cleaned it out and then ran roughly 12l of fuel threw from one can into another to flush the sys. I did the return test and got roughly 20ml on the pass side and close to 40ml on the drivers side in 2 15second cracking intervals. My fuel rail relief valve is not leaking at all but engine still will not start on its own without a gas rag over the intake. I believe that I have at least 1 bad injector but will those number be bad enough to make it not start? Fuel rail pressure while cranking was 620psi max.. before I throw in a new set of injectors what should I be checking?
Thanks in advance
Sent from my SGH-I337M using Tapatalk
Thanks in advance
