LLY overheating when idle
ejr12d
Oct 2, 2020
5
2005 lly here with 308k miles.
HSP high flow bundle kit
Pcv reroute
Head gaskets were replaced about at 250k miles along with new water pump.
Truck has been running fine up until last week where I noticed temps went north of 200. It usually sits around 178-180 and maybe up to 198 on a hot day.
It got all the way up to 230 when I got off the expressway. It seems to only overheat when driving in the city and not on the expressway. Any input on this will be greatly appreciated.
ejr12d
Oct 2, 2020
5
Radiator/intercooler clogged with debris? Ever "clean the stack"?
Fan clutch worn out? Ever replace that?
Tstats ever been replaced?
I have not cleaned it. Fan clutch seems fine to me, working properly, not loose or anything like that. Tstas were replaced about 60k miles ago.
550
With 305k on it, fan clutch probably has never been replaced and it's finally dieing. They are a wear item. While 200° isn't "hot" it's definitely cold side of warm.
Recommend replacement fan clutch is a Hayden 2886 it's about $80.00 give or take, can search "2886" there are plenty of reviews and posts about it.
And cleaning the cooling stack mainly the air side of the radiator
ejr12d
Oct 2, 2020
5
Got it thanks. Labor expensive for that? And should upgrade anything while I’m at it that’s related to that
550
Id have a hard time thinking they'd charge more than 1 hr to swap a fan clutch..
Downside most shops frown on you bringing your own parts..
No clue what shop rate is in your area
550
Some good info in this thread iirc the lly doesn't have the "wagon wheel" shroud
