Hi All, driving down the highway, my truck suddenly lost power and started running like an old tractor. Codes P0203 and P2149 came up. I still carry an ice pick just in case, but this time, to no avail. Towed it back home to diagnose. I pulled the FICM connectors and ohmed out CYL 3 injector harness, looked for any chaffing (I corrected all of the chafe points 18k miles ago during my complete build) and it came back ok. I ordered and replaced the cylinder #3 connector just in case since it had been picked years ago. Hooked everything back up, cleared the codes. Truck starts, runs about 10 seconds normal then instantly throws P0203 and P2149. I do have a random UNK1000 code but have been chasing that over a year - not sure if related. SO Pulled CYL 3 injector and sent to Lincoln for testing. I completely expected that 100% over reman to have an issue, but they just called and said the injector is fine! Back to the drawing board. Harness is good, injector is good. Is there a way I can test the injector with the harness connected? I doubt the new connector has issues but I'd like to check anyways. FICM is known to have issues and could be it, but considering it runs fine for 10-20 seconds, I was thinking that isn't it. Any ideas or recommends before I start messing with the FICM?
