LLY + LBZ RUNNERS/intake?
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
I'm going to be installing a modded LBZ CP3 soon. While I have it apart, would it be worth it to go ahead and pull the charger and install LBZ Runners and Y bridge? Would the LBZ set up improve over the LLY setup enough to make the hassle worth while?
I've seen both LLY/LBZ parts outside the motor and I know there is a large difference.
The turbo isn't stock. I've pulled it several times and can probably get it out in about 30 min. So pulling it isn't as big of a deal as the stocker.
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
If your going to change the y-bridge, i would look at the ones all season performance or rickd lance makes instead of the stocker. And if you havent already done it take out the egr system completely
Tony Burkhard
Allseason Diesel Per.
I would keep your intake runners or install LB7 runners if you were going to go with a large aftermarket charger. The LB7 runners have a larger tank on them. I know the mouth opening is larger with the LBZ but our Hi-Flow 3" Intake bridge with the LB7/LLY flanges flows the same as our LBZ/LMM bridge.
There is no longer the need to change to LBZ intake runners with my Hi-flow bridges.
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
Thanks everyone. I have seen the rdl stuff. But I was thinking of using stock LBZ simply for the price. It's a lot cheaper.
The EGR is gone. Hasn't been in the truck for quite some time. I used a lb7 bridge to delete it.
