so far so good! on the injectors. . .tony b said it would work with out any probs,took his word on it,you do have to mod the injector plugs on the wiring for the truck,other than that everthing is working ok.
the only thing he said you would have to change to run a lbz in a lly truck are
the timing gear on the crank change to lly and mod the injector plugs thats it,we used our old sensors and etc just because we knew that were all working ,but we did use the lbz pump. intake,but i modded it look for pics on my page.
i couldnt use any of the fuel line holders because i had modded the intake so much bigger. . . .
but that was a good trade off. you cant tell from the video but when the truck comes up on boost it sounds like a 2.6/3.0 truck with a stock charger,but that maybe because of the bigger boost tubes and intake not really sure.
if you want to know any thing ask away!
georgia duramax the lights came from a place called "galls" thats a store for firefighters etc. . .
