Real long story. Here's the condensed. Customer brought in an '03 5500 LB7 6 speed with a no start. Said he ran out of fuel and put some out of a dirty can to get home. Ended up finding a sheared cam pin along with trashed injectors and a melted piston.
Ordered a used engine and it shows up as a LLY. Salvage yard doesn't have an LB7 and I need to get this truck running ASAP or my ass is grass.
What would be fastest, cheapest, easiest?
1-Put entire LLY engine with turbo and electronics. I think I can get the ECM. I have everything but the LLY ECM and cab harness. What do I have to do to the original cab harness? The salvage yard hacked it all to hell. Engine harness is OK
2-Use LLY engine with LB7 turbo and electronics. Heard of this but they say it takes a bunch of tuning to make it run right. I have a V2 but don't know squat about tuning and don't want to learn on a customers truck. I would pay someone for a tune that works.
3-Use LLY short block and LB7 top end. This is a last resort because the LB7 heads need some valves and at least 4 injectors.
I already paid the core charge. I own a LB7 and a LLY, so I can use what's left over on my stuff or other customers trucks.
