Hey guys. New to the site... Having issues with my 2005 lly.
1093 code when under load at highway speeds. Replaced the filter and housing assembly. Replaced relief valve. Replaced rubber hoses to and from fuel filter. Conducted bottle test, no fuel present at relief valve after cycling under load. Used scantool to command 25k psi (160mpa) and it wouldn't produce more than 13,500 psi. Ran injector return test, less than 2 ml return from each of all 8 injectors... tested while cranking, ficm disconnected, 15 seconds each injector. However, on each bank, there was 42ml that came from the return line, which was disconnected from all injectors as well as the relief valve.... Any ideas?
