LLY Injector Rates Good or Bad?
05D-Max
Nov 25, 2011
30
How do they look? Truck is warm at 185*, Stock tuning
In Park
1; .8
2; -0.1
3; -0.3
4; -1.0
5; -0.1
6; -1.1
7; -1.3
8; 3.7
In Drive
1; 1.5
2; -1.2
3; .3
4; -0.9
5; -0.1
6; -1.3
7; -1.8
8; 3.6
dmax711
Mar 4, 2011
1,057
concord, north carolina
imo i wouldnt worry about it until its out of spec. I replaced 2 over the summer there not bad at all to do. If it was drasticlly out of spec id replace it but your not there yet..
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
I'd try running the GM injector cleaner first. I believe that when it's on the plus side it is adding fuel in order to have a good idle. So the concern of filing you crankcase with diesel isn't there as oppose to the negative, pulling fuel away to obtain a smooth idle.
Or I have it back asswards. :D
I would try the injector cleaner.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,195
359
At Da Beach
Run a whole bottle of diesel Klean to a tank of fuel, basically quadrouple dose it............
Bet it comes down a bit for you.........l
05D-Max
Nov 25, 2011
30
Ok guys I ran a whole 32oz bottle of Diesel Clean and here are the results. Let me know what you think.
Park
1. .3
2. -.5
3. .3
4. -1.5
5. -1.1
6. -1.0
7. -0.3
8. 3.9 :mad:
Drive
1. .9
2. -2.3
3. .7
4. -1.9
5. -1.4
6. -2.5
7. .5
8. 4.3
bradyn
Sep 22, 2010
kansas
8 got worse..Idk where I heard this but I have always uses a quart of tranny fluid in a full tank every couple of months. The detergents in the tranny fluid are good cleaners. Really helps my fpr when it starts surging.
05D-Max
Nov 25, 2011
30
Will it cause any problem as it is now? I dont have a rough idle or lope but it dose have a small haze at idle.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
it wont cause a problem as it is now. i say run more treatment. when you start getting visible soke out the tailpipe and its way out of spec, replace it. im sure your truck drives normal right now.
