Hey guys and gals,
Working on an 05' lly...The balance rate on Cyl. #3 was 15. Replaced the injector and this is the result. No change, however the truck does run better. No smoke, just a slight "lope" at idle. When I say cylinder 3, that is passenger side, second in looking from the front. Does EFI balance rate match the GM cylinder number? I know DVT does not....Any ideas? The truck still has the same codes as before, p0303 (cyl 3 misfire) and a p1229 also cyl. 3 related.
Any help would be great!
Thanks!
Dylan
Thanks!
Dylan
