LLY Injector Balance Rate Question
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Working on a lly. Trying to figure out if its a harness issue or a actual bad injector causing this. Idles rough. If I unplug #7 nothing changes. Tested 400+ of compression. No blowby. I did just tried the ice pic. Cant see any worn wires. Any suggestions on where to look?
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Injector issue.. 15 is a dead hole as that's as far as the rates read.
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
After replacing #7 is it still doing it? I had #2 stuck in a LMM a few years ago. Made 2 other injectors look bad along with all pretty bad balance rates, after replacing #2 all injectors were under +/-2.5...but truck had 287,xxx miles too...
pizza pig
I Like to Party
Feb 13, 2012
266
CT
My number 7 was consistantly giving me issues last year. I replaced it and #3 started being whacky, replaced it with a good used, and #4 started to go out of bounds. I said screw it and replaced basically the whole fuel system because I wanted no issues ever again.
Sometimes these trucks are weird man. Fricken curse of the LLY. Tony Martino nicknamed my brothers truck the black cloud because nothing ever went right when we flashed it :rofl:
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Also need to see the fuel rate. But -7 means the ecm is not commanding a main shot of fuel to that injector basically, and +15 means it is commanding 15mm3 of fuel moreto that cylinder than what the fuel rate is.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I will pull that out when I get more time. Another thing I forgot to mention is a truck runs great after 15mph.
carl.swoyer
Jan 31, 2016
90
My 05 lly had #2 &#7 injectors shorted out. Caught it while under warranty. Been running strong since. Side note there was a recall on the harness
Sent from my XT1254 using Tapatalk
