Lly hsp y bridge?
tbarn33
Nov 17, 2015
Wisconsin
I have a hsp 3 inch bridge for my lly and it has a muting tab on it that I'm trying to figure out what is supposed to bolt to it. First picture is a whole picture of the bridge and the second is of the bracket I'm talking about thanks.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
It's for a MAP sensor.
tbarn33
Nov 17, 2015
Wisconsin
Is it for if your using an aftermarket one for data logging or something then? I didn't have any wires or sensors left over on the install.
countrycorey
Trust Me I'm an Engineer
Jan 30, 2010
1,512
35
LA
It's for your factory MAP sensor, it bolts to that just like it was bolted to your factory bridge
Corey
5,817
Corey
Factory lly is in the intake runner like the Cali emission lb7
OP, you will need to plug it off. It's for a map sensor like said before but only federal emission lb7s use that spot.
countrycorey
Jan 30, 2010
1,512
35
LA
Learn something every day. Thanks James!
Corey
onebaddmaxxx
1,212
Cecil County Md
No need to plug it off. It is solid and you have to drill it if you plan on using it. Otherwise leave it alone.
tbarn33
Nov 17, 2015
Wisconsin
OK thanks guys I noticed it wasn't drilled through so I wasn't sure if there was some support that was supposed to bolt to it or what the deal was.
