Im sure this has been done before but Im unsure of exactly what needs to be done so..
Can I swap LLY heads, injectors, fuel lines etc along with ECM and to ditch my stupid LB7 injectors? If so what will this all entail as far as electronics?
Thanks
That was a good read but I would switch over to a lly stock turbo most likely so if I just get an LLY wiring harness will it all plug into my connectors on the truck side
Seems like alot of work with little gain if not alot of funky LLY down falls , injectors are easy to change IMOP , and most trucks will only need them changed once ,I'll tell you what you start the swap first and i'll start injectors and lest se who is finished first Now a LBZ swap then :thumb: though not possible with out a complete doner truck.
This would only be if my injectors down the road fail. I'm not concerned so much about work involved as longevity. Trust me if the price was right I'd buy an LBZ donor to make mine an lbz
