I have an 05 Chevy 2500HD crewcab ,longbed 4X4 with the 6.6 LLY Diesel , I bought the motor was apart," front left corner" I have put together and it runs pretty good, 255K on it, problem is it will start and run normal for about 3 minutes,, it will shift all gears, and run down the road, then it happens, the motor will not rev over 2100 RPM, it is not in LIMP mode, I can let off the fuel ,it will shift up thru all gears, will run 65-70 MPH, message board on dash says " change fuel filter ". running down the road if you stomp on it, it will shut down like its starving for fuel, runs great at the start , will smoke the tires, till the limit hits, I've changed fuel filters 3 times now, including today, got 3 minutes out of it , and the 2100RPM is back, if you shut it down for 5 minutes it will run like it should for 2-3 minutes, and back to 2100RPM, I'm changing the fuel/water separator sending unit in the morning with the hope that the float has a hole and is being pushed up and plugging the filter passage, any and all help would be greatly welcomed, thanks in advance
