Lly egr blocker plate
cetane4
Feb 15, 2011
Hi I have an 05 lly an was considering doing an egr blocker plate with fingerstick, will this improve power? Change the sound of my truck? I understand it will make things cleaner in the engine just curious what else it will improve? An is it worth it? Thanks for all the help
ripmf666
15,123
14
47
Wentzville Mo
Will not change the sound. But if your doing Efi live you will not need the stick. Once you turn up the power the blocker plate helps from popping open the egr valve. I think you would find a better gain from a egr delete.
616samuel
Apr 26, 2011
178
Rockford, Michigan
X2 do this mod asap! maybe not the full delete, but i do highly recommend it! depending on the mileage on your truck, you'll have a lot of nasty black crud in your intake track & the full delete will get rid of the stock intake y-bridge.
