LLY ECM and TCM pinouts
thunder550
1,176
Phoenix, AZ
Anyone have diagrams of the ECM and TCM pinouts for a 2005 LLY? I am trying to diagnose a couple of codes...wanting to check continuity from the VSS and the accelerator pedal to the ECM and/or TCM.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Thunder I can get them for you in a little while if no one else has.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
rcashman
Jun 7, 2023
19
3
Idaho
Question. In the red tcm connector pin 31. Back probing I'm only getting 11.64 volts with KOEO. Bat voltage is 12.18 in the clr connector pin 3. Do you know if the "12 Volt reference" on pin 31 in the red connector has to be at or above 12 volt KOEO or is that 12 volt KOER?
Ron Nielson
762
141
Berryton, KS
References voltages (like the 5V reference supplied to 3 wire sensors) are supposed to be regulated to almost that exact voltage by the ECM. I would check with the engine running and see what voltage you get vs just key on. A battery voltage of 12.18 is a low battery, about 50-60% charged. Put it on the charger.
rcashman
Jun 7, 2023
19
3
Idaho
Yeah i put the charge on it. I thought it should be closer to 12v Got a serial 2 com issue. Still tracing.
Narrowed it down to the entire trk :)
What a headache. :ROFLMAO:
Good thing im strong willed or thick headed. Haven't put a label on it yet.
