LLY cranking builds no rail pressure???
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
I have an LLY and it has an Airdog 150 lift pump on it that has approximately 9 psi fuel pressure when key is on. I can crank the truck for 30 seconds and it won't build any rail pressure, if I pinch lift pump return line and get 15 psi+ it fires right up, then I can un-pinch it and truck runs and drives great. Shut it off 10 seconds, same problem. I took engine return line loose at quick connect by driver's valve cover and run in a jug, at 9 psi lift pump pressure it won't return an ounce of fuel and won't start. At 15 psi lift pump pressure it just nearly trickles into the jug while running. Also if I get it running with 15 psi and unplug lift pump it dies IMMEDIATELY! Factory fuel filter head is now bypassed since this started happening. Fuel tank also has billet sump installed on bottom. I used a piece of clear hose bypassing stock fuel filter housing and was expecting to see lots of air bubbles, but no real fuel movement like I expected to see. The pressure sensor is T'ed into the clear fuel line between FICM and fuel line fitting on passenger front of valve cover. Also with engine running and clamp removed it runs about 11-12 psi at idle and when I command rail pressure to 23,000 psi it maintains 21,500 psi, just a little short. It's an 05 LLY with 210,000 miles.
What do I check next?
02greysixer
1,829
North Central FL
Where are you reading the supply pressure and what are you reading it with. If you're reading pressure at the lift pump I'd suspect a failed pump. Do you have or could you get a vacuum gauge like the dealer uses?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
02greysixer
1,829
North Central FL
If I were you I'd rig up a temp tank using your filter bypass hose and go directly to the cp3. If it starts and runs normal you have something going on with the supply pump or plumbing before/after. If it still doesn't start maybe some kind of cp3 issue?
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
I bypassed the Airdog and installed a different fuel filter head (used) and I bled the system and got it running. As long as I keep the primer pumped up it runs fine, when I quit pumping and the pressure drops below 5 psi it dies.
I still had clear hose inline and was not sucking any air? Is there any way the gear pump on the back of a cp3 can fail or leak internally and not pull enough vacuum to pull fuel to feed the cp3?
13,713
775
I removed the cp3 and replaced the Cascade Valve and it starts and runs great...
Good to know. Thanks for sharing the fix. Was the spring inside it broken, or did you bother inspecting what was going on with it?
