Figured out the piston oil ring was bent out of the box. New one came and all is good. Had to clean up a burr on the oil ring land but everything looked ok.
Moving on to piston protrusion, I had thought the performance cast pistons had .010” off of stock. With that, I planned GRADE C as the deck was milled .008” which usually calls for the “D” gasket which has +.010” thickness. Based on what I’m seeing, the pistons aren’t cut at all vs OEM unless my machine shop botched the deck process. I doubt that’s the case as everything else is right where it should be.
Tallest protrusion I have is .019”. Most are .0170-.0180 on the top side and .0145-.0160 bottom.
Thoughts??
Thoughts??
