lly coolant problem
lly dmax
Jan 2, 2011
14
I have a coolant problem. It has spewed out of the over flow tube a couple times and ill add coolant and it will still read low coolant level. and a couple times it has went from cold to red line to cold then to its running temp. any ideas
Chevmeister
Big Dooley
Dec 3, 2010
281
Garnet Valley, Pa
No ideas, but I'm experiencing a similar problem with an 05. Staying tuned for any awnsers.
I was told to check upper radiator hose in the morning cold. If it's hard it could be head gaskets.
lly dmax
Jan 2, 2011
14
but what would be the best for sure way to find out if thats what it is without taking it somewhere. I was also told maybe the thermostats.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
You could always remove the cap on the tank and see if it is bubbling back up inside there.
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
Take it to a shop or an auto zone type place and have a test done for dissolved hydrocarbons in the coolant. That will answer your question.
rossi
Jun 10, 2009
24
Head gaskets
Hi sorry to hear about the truck. My 04 LLy went at around 190000km. If your truck is blowing antifreeze out the over flow and hoses are hard it probably is the head gasket. Watch for white smoke coming out of exhaust as anti freeze drains into cylinder walls. When mine finally went I had no heat and it smoked like a bugger. The cost of repair is not cheap mine cost 6500 be sure that when they do it to upgrade head bolts. Personally I thyink a class action suit should be launched as chevy knew they were having problems with the 04 to mid 06 gaskets.
5,818
x2 and pressureize the system, pull the glow plugs, let sit over night and see what cylinders (if any) have water in them. id diagnose it fully before throwin money at it
lly dmax
Jan 2, 2011
14
thanks. im testing it tonight for exaust gases in the coolant. there hasnt been any white smoke yet or any drop in the air. ill keep you all posted.
Chevmeister
Big Dooley
Dec 3, 2010
281
Garnet Valley, Pa
Well let me know what I have to fix on mine. Ive almost decided its head gaskets, but i want to know for sure. Im thinking of pulling the motor and doing ehem, theres an oil leak somewhere and some new seals and gaskets are in order anyway.
lly dmax
Jan 2, 2011
14
the exaust gas test didnt show much. changed thermostats pressure tested it. it stayed steady around 15 to 16 for quite some time. then vaccume tested it and stayed steady around 25 for quite some time. then i drove it back home about thirty miles. got up this morning and drove it feeding cows mostly at an idle and coolant coming back out of the over flow. idk
Colt
Jul 23, 2010
523
Can I check my LBZ vin to tell if it's one with the weaker gaskets? I did read a little on this one time and couldn't finish the check of vin etc. Pisser deal out of warranty and should be stood by GM to change them. No damn diff. than injectors on LB7s guys have to eat. Looking at how much it took for GM to throw in on the LB7 issue of injectors makes for bad blood.
workin' diesel
factory tuned
Nov 13, 2010
630
Coalhust, AB Canada
Interesting, I just had to fill my overflow tank last night after the Low Coolant light came on. It has been a long time since I filled it, but since I bought it, it has happened a few times. Has me a bit concerned also.
lly dmax
Jan 2, 2011
14
took the gaskets off and both are cracked in a couple places each. so just an ordinary gasket swap. but i do want to know how much tensile strength stock head bolts will hold.
schulte
Jul 31, 2010
449
CT
Head gaskets?
Are you replacing the head bolts?
