Help: little lost
efituned6.6
WOLFPACK RACING
May 26, 2010
14
OKLAHOMA
my ecm fried and i bought a used one. well now my truck works it just doesnt start and the security light is on? do i have to take it to gm and have it reflashed or what?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Did you try to turn off VATS? If that doesnt work I think theres a code to marry the ecm to hte truck with if you have about an hour of time.. It involved trying to start the truck, then waiting for 10 mins with the key on and try starting again or something of that nature IIRC
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Justin, I see you called. Ill try to get a call back to you tonight. Trying to finish some stuff up here.
Try this...
When you try to start truck and it shuts down, the security light will light up on the dash. This is telling you VATS has been enabled. This is common when switching out controlers, or sometimes letting the truck sit without battery power for long periods of time. Follow the instruction to do the VATS relearn process.
Try to start it, then turn the key back to run. DO NOT TURN IT TO OFF.
Wait 11 minutes (time it).
Try to start again, then turn key back to run.
On the third cycle, it will ignore the VIN differences in the various modules and will start.
A Tech2 can be used to do this instead waiting time.
