Has anyone installed line lock? I am looking at installing one in my truck to help in the burn out box when i go to the drag strip. Just looking for any insight or direction as to which kit would be best.
Caleb Baker had one on his drag zf6 for staging. Front wheels only. Went to a toggle that returned to off if you let go of it(not sure the technical name for that type) on the shifter.
You only need 1 solenoid on the front brake line coming out of the master
Quote:
Have you personally done this on a gm truck with ABS and had no ill affects from the ABS?
