LLY: Limp shifter lever, where to get shifter?
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Just curious as to where I can buy a new shifter lever for my Lly. Got the common limp lever issue. Sometimes it's weird going into park aswell. Thinking it just needs a little R&R. Thanks! Appreciate it!
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
If the torx bolt isnt just loose, its probably the column that is worn in which case it'll need replacing. Loctite that torx screw first see if that helps
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Ok Tim, I will try that for sure. I also was thinking about upgrading to Bens tap shifter, not sure if I really need the ally locker but the tap would be pretty cool!
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
So I took the plastic off the column to see the spring in there is all broken. That may explain the limp shifter, but all the torx are tight, so maybe it's the cable that leads up to the shifter? Anyway to tighten it?
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
What's included Justin? The internals? Where the lever meets I the steering column? I don't see why It wouldn't work?
paul06d-max
Nov 18, 2010
Fleece has a new updated version of the tapshifter!! Plug and play no boxes under the hood... its all built into the harness! All updated software, and a new clean look under the hood!
