Lily ECM programming
reece385
May 2, 2012
Ok I've found someone in my area that will program my ECM for a lily instead of lb7 but they don't know if it will effect the PCM any other computer on the truck so my question is what is this going to effect or mess up if I engine swap to an lily and have the ECM retuned to the 48v for the injectors instead of the 96 that in the program now for the lb7
Dirtymaxx03
3,109
go start a different thread. but just a heads up, if they dont know the answer to that, DO NOT let them touch your truck with a 10ft pole.
Mossy D
May 7, 2012
East Sparta Ohio
Hi this my first time here hope someone can help. Have 2005 lly n it is surging when in drive at a stop n throtle is real touchy it almost seams like a miss but its not . Im in east sparta ohio is there anyone close to me that knows anything ? Dont want too start changin parts . Oh n take off is not real great at all !
Josh2002cc
That Uncle
Apr 2, 2007
1,832
Exactly. This is not a good start to finding a shop who can tune an ECM. Shop around.
JRODS*LB7
Feb 1, 2012
642
SE Massachusetts
Where is fuel regulator n how should i test it ? This is my first diesel only had it 4 months T
:welcome3:
You should fill out your Sig let us know what you got yr,mods,etc.. It will make it easier on you and us ! Do you have efi live? Your reg is located on top of the cp3( injector pump) front of motor near thermostat housing sits in the gully of the motor
reece385
May 2, 2012
Will my 03 dmax work if I just install the ECM from the lly when i do the swap because I can get the ECM with the lly engine
13,711
772
Umm, what? How are they going to program an LLY tune into an LB7 ECM, and how is that going to have any affect on the voltage from the FICM?
FYI, PCM is another name for ECM, but it is usually used for a computer that controls both the engine and transmission. PCM=powertrain control module. Our trucks have an ECM (engine control module) and TCM (transmission control module). There is also an FICM (fuel injector control module) on the LB7 and LLY. The LBZ, LMM, and LML control injectors directly with the ECM.
Mossy D
May 7, 2012
East Sparta Ohio
Where is fuel regulator n how should i test it ? This is my first diesel only had it 4 months n really like to b able to wrk on it myself instead of gettin hosed by dealer
reece385
May 2, 2012
Ok so everything Ive seen on these forums say that it's a plug and at to swap a lb7 to an lly all u have to do is re tune the ECM to 48 instead of 96v for the injectors to work I'm trying to eliminate having to change out injectors again in another 75- 150,000 miles I use this truck to hot shot and that's how I make a living so I need to be sure that it will work before I get off into it and then have to change a lot more stuff or something like that not to mention the fact that I'll already be out what the lly is going to cost me
reece385
May 2, 2012
So all I have to do is re tune the ficm to pull 48 instead of 96 that is used to operate the lb7 ?
