how big of a charger?
see above
the converter loosed enough to allow the engine to spin?
about as loose as can get... IIRC, stall is around 2500 though the truck begins lurching before that
scenario... say a charger starts spooling @ 2500rpm.. it a 42XX or 4094 with a 1.XX turbine housing..A5k and the like
i would start dumping fuel 2300-2400rpm and increase timing as needed starting with 9-11* at ~60mm3 and slowly work my way up couple degrees at a time till i was happy with the results.
2500rpm @ 100mm3 im floating 20* +/- 3-4 depending on the truck dont ahve my tunes on this PC to double check... that is with a stock and comparabel charger... the A5ks i have done basicly i moved the whole table to the right on the rpm till i was in the effeciency area of the a5k.
i was still running 30* +/- @ 3000-3200rpm depending on how fast they reved the motor. shift point and whatnot...
speculation im shure pats timing tables starte roughly 1000rpms latter then a stock/mild turbo setup
if the only thing changed is timing this is bassicly what you will find.
added timeing creates pressure and clears smoke, increases repsonsiveness of the said engine and too much breaks stuff.
IMO black smoke doesnt spool a charger 1/2 as well as hazzy to clear smoke does.
JMHO
